ผู้เขียน หัวข้อ: Calcium Carbonate, CaCO3, Thailand Calcium Carbonate, GCC, PCC, Calcite  (อ่าน 867 ครั้ง)
polychemicals888
  • กระทู้: 233
« เมื่อ: มีนาคม 11, 2020, 08:52:57 AM »
More information of Calcium Carbonate (CaCO3)
Contact: Thai Poly Chemicals Co., Ltd. Thailand
Tel No. 6634 496284, 6634 854888
Fax No. 6634 496285, 6634 496680
Mobile No. 668 00160016, 668 98554004
Email address: thailandcalciumcarbonate@gmail.com
Email address: polychemicals888@gmail.com
Line id: thaipoly888
Line id: vanawanav
What?s App: +66800160016
Description
Calcium carbonate is a chemical compound with the chemical formula CaCO3
Synonyms
limestone, CaCO3, calcium carbonate, precipitated calcium carbonate, ground calcium carbonate, pulverized calcium carbonate, PCC, GCC, calcite, crushed marble, ground limestone, lime, aragonite, chalk, marble, pearl, whiting, champagne chalk, French chalk, albacar, calcium carbonate nanoparticle, aeromatt, calcium carbonate magnum gloss
Typical Applications
Plastics, rubber, coatings, inks, adhesives, and soil conditioner, building products, plastic filler, ceramic flux, asphalt filler, chemical processing, glass ingredient, water treatment, pesticide granules, dusting agent, welding rods coating, thermosets, thermoplastics, paints, coatings, adhesives, sealants, rubber, pharmaceutical, toothpaste, and food additive. Calcium carbonate has a wealth of uses: as a flux in steel production and in processing of non-ferrous metals; in bricks, mortar and concrete for construction; as a raw material in glass; in the construction of roads and dams; in the manufacture of paper, paints and dyes, carpeting and other floor coverings; and in the treatment of water, industrial waste, gases and household refuse. It is also used to reduce soil acidity in agriculture, to absorb water and add calcium in food products, and in sugar extraction. Calcium carbonate is a versatile additive for use in a wide range of plastic and elastomeric applications. Its regular and controlled crystalline shape and ultrafine particle size together with the hydrophobic surface coating, combine to the benefit of both polymer processing and subsequent physical properties.
Packaging
25 kg/bag, 500 kg/bag, 1,000 kg/bag
Storage Condition
Stored in dry, cool and good ventilation area
Shelf Life
36 months after manufacturing date
General Information
Product Name: Calcium Carbonate
Physical Form: White Fine Powder
Molecular Formula: CaCO3
Molecular Weight (g/mol): 100.09
pH: 8 to 10
Mohs Hardness @ 20?C:3.0
Specific Gravity (solids): 2.70- 2.71
Index of Refraction: 1.6
Crystallography: hexagonal
Classification
Calcium Carbonate (CaCO3) TSCA (SARA Title III) Status:
CAS Number
a) CAS No. 471-34-1 Calcium Carbonate (edible, pharma)
b) CAS No. 1317-65-3 Calcium Carbonate- limestone- (not edible)
E Number: E170
Calcium Carbonate (CaCo3) NFPA Ratings:
Health: 0 Flammability: 0 Reactivity: 0
Line id: vanawanav
