ไตรอะซีติน, ไตรอาซีติน, Triacetin, Glycerol Triacetate, Glyceryl Triacetate, CAS 102761
นำเข้า ส่งออก และจัดจำหน่าย โดย บจก.ไทยโพลีเคมิคอล
โทร 034496284, 034854888, 0861762992, 0824504888, 0868850111, 0898554004
อีเมลล์แอดเดรส, polychemicals888(at)gmail(dot)com, LINE ID: wuttpcc
TAG, Triacetin, Glycerol Triacetate, Glyceryl Triacetate
ไตรอะซีติน, ไตรอาซีติน, กลีเซอริลไตรอะซีเตต, กลีเซอรอลไตรอะซีเตต
PRODUCT APPLICATION:
Triacetin is used in a broad variety of different industrial applications such as cosmetics, toiletries, pharmaceuticals, food, metal working fluids, and etc. Properties like lubrication, mould release, consistency promotion, emolliency, stability enhancement, spreading or fatty, solvency and cleaning demonstrate the large variety of functions offered by these unique products.
PRODUCT DESCRIPTION:
The triglyceride 1,2,3-triacetoxypropane is more generally known as triacetin and glycerin triacetate. It is the triester of glycerol and acetylating agents, such as acetic acid and acetic anhydride. It is a colorless, viscous and odorless liquid with a high boiling point. It is an artificial chemical compound, commonly used as a food additive, for instance as a solvent in flavourings, and for its humectant function, with E number E1518 and Australian approval code A1518. It is used as an excipient in pharmaceutical products, where it is used as a humectant, a plasticizer, and as a solvent. Triacetin can also be used as a fuel additive as an antiknock agent which can reduce engine knocking in gasoline, and to improve cold and viscosity properties of biodiesel. It has been considered as a possible source of food energy in artificial food regeneration systems on long space missions
PRODUCT NAME: Triacetin
INCI Name: Triacetin
CAS Number 102761
EC Number 2030519
PACKAGING: 240 kg per drum
SYNONYM: Glycerol Triacetate, Glyceryl Triacetate, Glycerin Triacetate, Palmester
KEYWORD: ไตรอะซิติน, ไตรอะซิทิน, ไตรอาซิติน, ไตรอาซิทิน, ไตรอะซีติน, ไตรอะซีทิน, ไตรอาซีติน, ไตรอาซีทิน
กลีเซอรอล ไตรอะซีเตต, กลีเซอรอล ไตรอะซีเตท, กลีเซอรอล ไตรอาซีเตต, กลีเซอรอล ไตรอาซีเตท
กลีเซอริล ไตรอะซีเตต, กลีเซอริล ไตรอะซีเตท, กลีเซอริล ไตรอาซีเตต, กลีเซอริล ไตรอาซีเตท
กลีเซอริน ไตรอะซีเตต, กลีเซอริน ไตรอะซีเตท, กลีเซอริน ไตรอาซีเตต, กลีเซอริน ไตรอาซีเตท
นำเข้าไตรอะซีติน, จำหน่ายไตรอะซีติน, ขายไตรอะซีติน, ส่งออกไตรอะซีติน, ผลิตไตรอะซีติน
นอกจาก ไตรอะซีติน (Triacetin) ดังที่ระบุข้างต้นแล้ว บริษัท ฯ ยังเป็นผู้นำเข้า ส่งออก และจัดจำหน่ายสินค้าในกลุ่ม Hydrocarbon, Solvent, ไฮโดรคาร์บอน, โซลเว้นท์ อีกหลายรายการ ได้แก่
Acetate, อะซีเตต, อาซีเตต, อะซีเตท, อาซีเตท
Acetone, อะซีโตน, อาซีโตน, อะซีโทน, อาซีโทน
Base oil, 150SN, SN150, SN500, 500SN, 150BS, เบสออยล์, น้ำมันหล่อลื่นพื้นฐาน
Butyl acetate, BA, บิวทิลอาซีเตต, บิวทิลอะซีเตต, บิวทิลอาซีเตท, บิวทิลอะซีเตท
Butyl Carbitol, บิวทิลคาร์บิตอล, บิวทิลคาร์บิทอล
Butyl Cellosolve, บิวทิลเซลโลโซ้ล, บิวทิลเซลโลโซล์ฟ
Butyl Diglycol, BDG, บิวทิลไดไกลคอล, บีดีจี
Cellosolve Acetate, CA, เซลโลโซล์ฟอาซีเตต, เซลโลโซล์ฟอะซีเตต, เซลโลโซล์ฟอาซีเตท, เซลโลโซล์ฟอะซีเตท
Cyclohexanone, CYC, Nadon, Anone, ไซโคลเฮกซาโนน, ซีวายซี
Cyclohexyl Ketone, Hexanon, ไซโคลเฮกซิลคีโตน, ไซโคลเฮกซิลคีโทน
Diacetone Alcohol, DAA, ไดอะซีโตนแอลกฮอล์, ไดอาซีโตนแอลกอฮอล์, ดีเอเอ
Dichloromethane, DCM, ไดคลอโรมีเทน, ไดคลอโรมีเธน, ดีซีเอ็ม
Dimethylformamide, DMF, ไดเมทิลฟอร์มาไมด์, ไดเมทธิลฟอร์มาไมด์, ดีเอ็มเอฟ
Dimethyl Ketone, DMK, ไดเมทิลคีโตน, ไดเมทิลคีโทน, ไดเมทธิลคีโตน, ไดเมทธิลคีโทน, ดีเอ็มเค
Ethyl acetate, EA, EAc, เอทธิลอาซีเตต, เอทิลอาซีเตต, เอทธิลอะซีเตต, เอทิลอะซีเตต
Ethylene glycol monobutyl ether, เอทิลีนไกลคอลโมโนบิวทิลอีเทอร์
Glycerine, Glycerine USP, Refined Glycerine, กลีเซอรีน, รีไฟน์กลีเซอรีน, กลีเซอรีนบริสุทธิ์
Glycerol, Glycerol USP, Refined Glycerol, กลีเซอรอล, รีไฟน์กลีเซอรอล, กลีเซอรอลบริสุทธิ์
Glycol, Glycol Ether, ไกลคอล, ไกลคอลอีเทอร์
Ketohexamethylene, คีโตเฮกซาเมทาลีน, คีโตเฮกซาเมทธาลีน
Methylene Bichloride, MBC, เมทิลีนไบคลอไรด์, เมทธิลีนไบคลอไรด์
Methylene Chloride, MC, เมทิลีนคลอไรด์, เมทธิลีนคลอไรด์, เอ็มซี
Methylene Dichloride, MDC, เมทิลีนไดคลอไรด์, เมทธิลีนไดคลอไรด์
Methyl Ethyl Ketone, MEK, เมทิลเอทิลคีนโตน, เมทิลเอทิลคีโทน, เอ็มอีเค
Methyl Isobutyl Ketone, MIBK, เมทิลไอโซบิวทิลคีโตน, เมทิลไอโซบิวทิลคีโทน, เอ็มไอบีเค
Normal Methylpyrrolidone, N-methylpyrrolidone, NMP, นอร์มอลเมทิลไพร์โรลิโดน, เอ็นเอ็มพี
Nonylphenol Ethoxylate, NP, NP6, NP9, NP15, โนนิลฟีนอลอีทอกซีเลต, โนนิลฟีนอลอีทอกซีเลท
Paraffin Oil, Liquid paraffin, พาราฟินออยล์, พาราฟินเหลว, น้ำมันพาราฟิน
Perchloroethylene, PCE, Perstabil, เปอร์คลอโรเอทิลีน, เปอร์คลอโรเอทธิลีน, พีซีอี, เปอร์สเตบิล
Pimelic Ketone, พิเมลิกคีโตน, พิเมลิกคีโทน, ไพเมลิกคีโตน, ไพเมลิกคีโทน
Polyoxyethylene Castor oil, Castor oil 36 mole Ethoxylate, คาสเตอร์ออยล์อีทอกซีเลต
Polyethylene Glycol Castor oil, โพลีเอทิลีนไกลคอลคาสเตอร์ออยล์
Propyl acetate, nPA, โพรพิลอาซีเตต, โพรพิลอะซีเตต, โพรพิลอาซีเตท, โพรพิลอะซีเตท
Propylene glycol mono methyl ether, PM, โพรพิลีนไกลคอลโมโนเมทิลอีเทอร์
PTT Rubflex, PTT Rubflex 105, PTT Rubflex 111, PTT Rubflex 130, พีทีทีรับเฟล็กซ์
Rubber Oil, Rubber Process Oil, Rubberflex, รับเบอร์ออยล์, รับเบอร์โพรเซสออยล์
Silicone Oil, Silicone Fluid, Liquid Silicone, ซิลิโคนออยล์, ซิลิโคนเหลว, ซิลิโคนฟลูอิด
Tetrachloroethylene, เตตระคลอโรเอทิลีน, เตตระคลอโรเอทธิลีน
Trichloroethylene, TCE, ไตรคลอโรเอทิลีน, ไตรคลอโรเอทธิลีน, ทีซีอี
Tris Nonylphenyl Phosphite, TNPP, ทริสโนนิลฟีนิลฟอสไฟต์, ทีเอ็นพีพี
White oil, White mineral oil, ไวท์ออยล์, ไวท์มิเนอรัลออยล์, น้ำมันขาว, น้ำมันแก้ว
รายการสินค้าในกลุ่ม Propylene Glycol, PG, โพรไพลีนไกลคอล, โพรพิลีนไกลคอล ที่บริษัท ฯ จำหน่ายในปัจจุบันได้แก่
Dipropylene Glycol, DPG, ไดโพรพิลีนไกลคอล, ไดโพรไพลีนไกลคอล, ดีพีจี, ไดไกลคอล
Monopropylene Glycol, MPG, โมโนโพรพิลีนไกลคอล, โมโนโพรไพลีนไกลคอล, เอ็มพีจี, โมโนไกลคอล
Monopropylene Glycol EP, MPG EP, EP grade, โมโนโพรพิลีนไกลคอล เกรดอีพี, เอ็มพีจี เกรดอีพี
Monopropylene Glycol USP, MPG USP, USP grade, โมโนโพรพิลีนไกลคอล เกรดยูเอสพี, เอ็มพีจี เกรดยูเอสพี
Monopropylene Glycol Pharmaceutical grade, โมโนโพรพิลีนไกลคอล เกรดยา, เอ็มพีจี เกรดยา
Polypropylene Glycol, PPG, P425, P3000, โพลีโพรพิลีนไกลคอล, โพลีโพรไพลีนไกลคอล, พีพีจี, พี425, พี3000
รายการสินค้าในกลุ่ม Ethylene Glycol, EG, เอทิลีนไกลคอล ที่บริษัท ฯ จำหน่ายในปัจจุบันได้แก่
Ethylene Glycol, EG, เอทิลีนไกลคอล, เอทธิลีนไกลคอล
Diethylene Glycol, DEG, ไดเอทิลีนไกลคอล, ไดเอทธิลีนไกลคอล, ดีอีจี, ไดไกลคอล
Monoethylene Glycol, MEG, โมโนเอทิลีนไกลคอล, โมโนเอทธิลีนไกลคอล, เอ็มอีจี, โมโนไกลคอล
Polyether Glycol, PEG, PEG Food Grade, โพลีอีเทอร์ไกลคอล, โพลีอีเธอร์ไกลคอล, พีอีจี เกรดอาหาร
Polyethylene Glycol, PEG, โพลีเอทิลีนไกลคอล, โพลีเอทธิลีนไกลคอล, พีอีจี, โพลีไกลคอล
PEG 200, PEG 300, PEG, 400, PEG 600, พีอีจี 200, พีอีจี 300, พีอีจี, 400, พีอีจี 600
PEG 1000, PEG 4000, PEG, 8000, พีอีจี 1000, พีอีจี 4000, พีอีจี, 8000
รายการสินค้าในกลุ่ม Ethanolamine, EA, เอทานอลเอมีน, เอทาโนลามีน ที่บริษัท ฯ จำหน่ายในปัจจุบัน ได้แก่
Ethanolamine, Monoethanolamine, EA, MEA, โมโนเอทานอลเอมีน, โมโนเอทาโนลามีน, อีเอ, เอ็มอีเอ
Diethanolamine, DEA, ไดเอทานอลเอมีน, ไดเอทาโนลามีน, ดีอีเอ
Triethanolamine, TEA, ไตรเอทานอลเอมีน, ไตรเอทาโนลามีน, ทีอีเอ
Diethylene Triamine, DETA, ไดเอทิลีนไตรเอมีน, ไดเอทธิลีนไตรเอมีน, ดีอีทีเอ
Triethylene Triamine, TETA, ไตรเอทิลีนไตรเอมีน, ไตรเอทธิลีนไตรเอมีน, ทีอีทีเอ
รายการสินค้าในกลุ่ม Glycerine, Glycerol, กลีเซอรีน, กลีเซอรอล ที่บริษัท ฯ จำหน่ายในปัจจุบันได้แก่
Glycerine Pharmaceutical grade, Glycerol Pharmaceutical grade, กลีเซอรีน เกรดยา, กลีเซอรอล เกรดยา
Glycerine EP grade, Glycerine-EP, Glycerol EP grade, กลีเซอรีน เกรดอีพี, กลีเซอรอล เกรดอีพี
Glycerine USP grade, Glycerine-USP, Glycerol USP grade, กลีเซอรีน เกรดยูเอสพี, กลีเซอรอล เกรดยูเอพี
Glycerine 99.5, Glycerol 99.5, Glycerine 99.5 PCT, Glycerol 99.5 PCT, กลีเซอรีน 99.5, กลีเซอรอล 99.5
Glycerine 99.7, Glycerol 99.7, Glycerine 99.7 PCT, Glycerol 99.7 PCT, กลีเซอรีน 99.7, กลีเซอรอล 99.7
รายการสินค้าในกลุ่ม Alcohol, แอลกอฮอล์ ที่บริษัท ฯ จำหน่ายในปัจจุบันได้แก่
Ethanol, Denatured Ethanol, เอทานอล, เอทธานอล
Ethyl Alcohol, Denatured Ethyl Alcohol, เอทิลแอลกอฮอล์, เอทธิลแอลกอฮอล์
N-Butanol, Butyl alcohol, บูทานอล, บิวทานอล, บิวทิลแอลกอฮอล์
Methanol, Methyl Alcohol, MeOH, เมทานอล, เมทธานอล, เมทิลแอลกอฮอล์, เมทธิลแอลกอฮอล์
Isopropanol, Isopropyl alcohol, IPA, ไอโซโพรพานอล, ไอโซโพรพิลแอลกอฮอล์, ไอพีเอ
Cetyl Alcohol, Hexadecanol-1, ThaiOL 1698, ซีติลแอลกอฮอล์, ซีทิลแอลกอฮอล์
Stearyl Alcohol, Octadecanol-1, ThaiOL 1898, สเตียริลแอลกอฮอล์
Cetyl Stearyl Alcohol, Fatty alcohol C16-C18, ThaiOL 1618, ซีติลสเตียริลแอลกอฮอล์
Fatty Alcohol, แฟตตี้แอลกอฮอล์, แฟทตี้แอลกอฮอล์
THAI POLY CHEMICALS COMPANY LIMITED, บริษัท ไทยโพลีเคมิคอล จำกัด
