Special Bangkok Thailand CAR Rental ให้บริการเช่ารถตู้ไปทั่วไทย LPG special rate
vancarforday เราจัดให้บริการ
ให้เช่ารถตู้ สำหรับใช้ในการเดินทาง ยินดีต้อนรับ นักท่องเที่ยว มีรถ เอ็นจีวี
Terms and ConditionsRates included :
- GPS system equipped the passengers safety.
Rates excluded :- Any loss or damage of the properties left by the passengers is not in our responsibility.
WITHIN BANGKOK – Hire a car and driver to show you some of the many sights in Bangkok and/or take you to local markets for some shopping.
Tips to Maintain the Your Car- No Salt – If you live at the beach or in a harsh winter area, salt can break down your car’s paint and cause metal to rust much faster. It’s important to keep your car protected with frequent car washes and wax your vehicle’s exterior. (Spiffy Mobile Detail can do this for you if you chose the 3,4, or 5 service!)
- Change the Air Filters – Keep the car smelling great and help your HVAC system run more efficiently by changing your air filter with every 1-2 oil changes. This is an easy DIY job, learn how to change your air filters here.
- Park it Inside – This is a tough one if you don’t have a garage. Or like me, your garage serves a purpose other than storing your automobiles. If parking your vehicle inside isn’t an option, try not to park under trees (birds and falling limbs can do damage to your car.) And be sure to refer back to tip number 1.
Drive Your Van in the Right Way
The way you drive your van can affect how quickly your tyres wear over time. Through approaching corners more slowly and not being so heavy on the brakes, you can reduce the levels of abrasion and keep your tyres in top condition for longer.
PAYMENTS BY HIRERf) charges for late return of the vehicle;
k) any surcharges in connection with the use of a debit or credit card by the hirer; and
HIRER'S OBLIGATIONS c) the oil in the vehicle is maintained at the proper level;
h) no part of the engine, transmission, braking or suspension systems are interfered with;
SERVICESHoliday Transfers There is no better way to start a holiday then to begin it with a safe transfer from the airport to your beach destination in Cha Am, Hua Hin, Pattaya, Rayong or Koh Chang. Start your vacation with a safe transfer for your holiday pleasure.
Maintain Your Camper Van for DrivingMany people do not want to address any chores while on holiday, but there are a few quick, easy steps that one can take to maintain a camper van on journeys. These steps include maintaining the camper van's engine, chassis, tyres, and exterior.
![](http://www.vancarforday.com/dr3.jpg)
วิธีการเช่ารถตู้
ในตอนนี้พวกเราจะเห็นได้ว่า ธุรกิจการเช่ารถตู้ มีให้เลือกเช่ารถตู้มากไม่น้อยเลยทีเดียวหลายชนิด ซึ่ง มีรถตู้แบบใหม่ออกมาวิ่งกันมากเกลื่อนกล่นเลยทีเดียว ซึ่งธรรมดาส่วนใหญ่จะ
เป็นรถโตโยต้า คอมไม่วเตอร์ ถึง 99.9% อาจจะเป็นไปได้ว่าจะมีรถยนต์ของประเทศจีนเริ่มเข้ามาวิ่งบ้าง แต่ว่ายังไม่ค่อยเป็นที่นิยม เนื่องจากว่าผู้ใช้ยังตระหนักถึงการบำรุงรักษา แล้วก็เรื่องของอะไหล่ใน
ระยะยาว สำหรับ ในเรื่องเกี่ยวกับเทคนิค
ข้อเสนอ วิธีการเช่ารถตู้
การเช่ารถตู้นั้น ทาง vancarforday.com ( บริการรถตู้ให้เช่า ) ก็จะขอเสนอแนะเทคนิคการเช่า รวมทั้งกระบวนการเช่ารถตู้ ที่ถูกแนวทาง ดังต่อไปนี้
รถตู้ให้เช่ายี่ห้อโตโยต้ารุ่นคอมมิวเตอร์ที่เราๆท่านๆมองเห็นวิ่งกันอยู่ทั่วไปนั้นจะแบ่งออกเป็น 2 แบบ คือ
- แบบที่ 1 คือ รถยนต์ที่ใช้น้ำมันดีเซลซึ่งจะเป็นเครื่องยนต์กลไกระบบคอมมอนเรลธรรมดาที่เห็น
กันส่วนใหญ่ตัวถึงรถจะเป็นสีบรอนซ์เงิน ประมาณ 99% (ประเมิที่เอาเอง)
- แบบที่ 2เป็นรถที่ใช้น้ำมันเบนซินซึ่งจำนวนมากเช่นเดียวกันจะมีการติดตั้งระบบNGVเข้าไปด้วยเพื่ออดออมค่าเชื้อเพลิงซึ่งจะมีแต่ว่าสีขาว(ยังไม่เคยมองเห็นสีอื่นเลย)
เช่า รถตู้ NGV แล้ว ดีอย่างไร ?
ถ้าเกิดกล่าวถึงความประหยัดอดออมค่าครองชีพของค่าเชื้อเพลิงแล้ว อย่างไรก็จำเป็นต้องยกให้รถตู้ NGV เพราะว่าเฉลี่ยรายจ่ายแล้วจะอยู่ที่ ประมาณ 1.5 บาท/กม. แม้กระนั้นถ้าเป็นรถยนต์น้ำมันรายจ่ายค่าเชื้อเพลิงจะ
อยู่ที่ราวๆ 5.0-5.50 บาท/กิโลเมตร ซึ่งจะเห็นได้ว่ารถยนต์ที่ใช้ NGV จะมัธยัสถ์กว่ารถยนต์ที่ใช้น้ำมันดีเซลประมาณ 4-5 เท่า ยิ่งเดินทางไกลมากมายมากแค่ไหน ความต่างของค่าใช้จ่ายยิ่งมากขึ้นเรื่อยๆอย่างมองเห็น
ได้แจ่มแจ้ง คนที่เคยใช้บริการเช่ารถตู้ NGV ต่างรู้กันดีถึงความประหยัดและมัธยัสถ์ แล้วก็ความแตกต่างเกี่ยวกับเรื่องค่าใช้จ่ายระหว่างการเช่ารถตู้น้ำมันกับรถตู้ NGV ก็เลยไม่ต้องฉงนใจ
ว่าทำไมรถตู้ NGV ถึงเต็มไปหมด (มองเห็นรถตู้บนท้องถนน หากเป็นสีขาวให้เดาไว้ก่อนเลยว่าเป็นรถตู้ NGV - ถ้าเป็นสีบรอนซ์เงินให้ทายใจไว้เลยว่าเป็นรถยนต์น้ำมัน) แล้วจะทราบได้อย่างไร
ว่าเส้นทางที่เราไปนั้นต้องจ่ายค่าเชื้อเพลิงประมาณมากแค่ไหน?.. เรื่องนี้ไม่ยากครับผม เพียงแต่พวกเรารู้ดีว่าที่หมายที่พวกเราจะเดินทางไปนั้นมีระยะทางกี่กม. แล้วต่อจากนั้นเราก็เอา 2 คูณ เพื่อให้เป็นระยะทางรวมไปและกลับ ได้แก่ไปเชียงราย ระยะทางราว 848 กิโลเมตร (ต้นทางเป็น กรุงเทพมหานคร) เอา 2 คูณ ก็จะได้ 1,696 กิโลเมตร ซึ่งเป็นระยะทางไปและกลับ
- หากเป็นรถตู้ใช้ NGV คุณต้องจ่าย (1,696x1.5) คร่าวๆ 2,953.5 บาท
- หากเป็นรถตู้ใช้น้ำมัน คุณจำต้องจ่าย (1,696x5.5) โดยประมาณ 9,328.0 บาท
ความปลอดภัยของรถที่ใช้ NGV
รถตู้ที่ใช้ NGV ทุกคัน ไม่ใช่ว่าอยู่ๆอยากไปติด NGV แล้วเอามาวิ่งได้เลยครับผม การติดตั้งต้องผ่านการตรวจสอบการวิศวกร แล้วก็ยังควรจะมีใบรับรองเพื่อยืนยันว่ามีการตั้งได้มาตรฐาน
แล้วก็มีวิศมือเซ็นต์รับ และก็ทุกๆปี ต้องนำรถยนต์ไปตรวจตราความสมบูรณ์ของอุปกรณ์กับบริษัทที่ได้รับอนุญาตจากทางการ พร้อมออกใบรับรองแบบปีต่อปี (ไม่ใช่ออกให้ครั้งเดียวใช้จนกระทั่งรถพัง)
หากเอ๋ยถึงเรื่องความปลอดภัย มีอีกข้อให้พิจารณา ระหว่างการเติมก๊าซกับการเติมน้ำมัน ถ้าเกิดเป็นการเติม NGV บางสถานีเขาจะให้ผู้โดยสารลงจากรถยนต์ เหตุผลเป็นเรื่องของความปลอดภัย
และรถจะต้องปิดเครื่องทุกครั้งจึงจะเพิ่มเติมให้ แต่จุดที่น่าสังเกตอยู่ที่หัวเพิ่มเติมก๊าส จะมิดชิด มีระบบระเบียบคุ้มครองปกป้องความปลอดภัยกว่าการเติมน้ำมัน ระบบความปลอดภัยจะสูงกว่าการเติมน้ำมันอย่างมองเห็น
ได้ชัด ธรรมดาเวลารถเข้าเติมน้ำมัน ถังใส่น้ำมันเปิด หัวจ่ายแทงเข้าถัง พินิจดีๆพวกเราจะมองเห็นไอของน้ำมันระเหยตลอดเวลา ยิ่งช่วงแดดร้อนมากๆจะเห็นกระจ่างมาก ถ้ามีสะเก็ดไฟนิดหน่อยเดียว เป็นเรื่องทันที ซึ่งถ้าหากเป็นการเพิ่มก๊าส NGV เราจะมองไม่เห็นในลักษณนี้เลย อีกอย่างคือ รถยนต์ที่เข้าเติม จะปิดเครื่องหรือไม่ก็ได้ (แม้ว่าเป็นกฏของความปลอดภัย)
Tours by Destination : Khao Lak
Tours by Interest : Thai Boxing
บริการเช่ารถตู้ไปไกลทั่วไทย ประกันภัยชั้น 1 ทุกที่นั่ง เชี่ยวชำนาญทุกเส้นทาง ภาคอีสาน หมดปัญหาห่วง
ภูหินรองกล้า สามารถขับรถขึ้นดอยได้
เครดิตบทความจาก :
http://www.vancarforday.com/Tags : รถตู้เช่า,รถตู้พร้อมคนขับ,เช่ารถตู้ด่วน
